Family Table BOM Balloon
I have an assembly with two instances into family table. I have generated drawing from the main file and created repeat region of Two-D type to accommodate BOM in a single table for all instances.
Issue I am facing is that even though it is a repeat region, the same table is not being recognised as repeat region when I intended to do ballooning of view using Create Balloons - All.
Requesting help on this.
I am open to share my test parts on which I am facing issue for your better understanding if required.
Thanks and Regards
Ketan
