Family table instance
  • March 9, 2011
  • 6 replies
  • 5452 views
Hi all,
i was wondering if there is a quick way of making a family table instance a stand alone model, not depentant on the generic from which it was created.
Regards
John
Hello.
If I understand you need to create independent model from instance model?
It's easy - just Open instance model and then click the command: File > Save a Copy ... and set New name.
Hi Vladimir,
i realized after my first post, that perhaps i could do as you describe, but there is more to this than i first explained. The family table instance has a drawing & an assembly associated with it. If i save a copy, yes i get an independant model, but i am forced to give it a new name. I just want to trick pro-e into believing that there was never a family table in the first place, that the generic model & instance were 2 separate models, & that the assembly & drawing containing the instance model can still regenerate.
Regards
John
Answer on your question: I just want to trick pro-e into believing that there was never a family table in the first place, that the generic model & instance were 2 separate models, & that the assembly & drawing containing the instance model can still regenerate? - If I know - this is not possible.
NOTE:
If your model is referenced in drawing as family table model (instance model) - it is not possible change this dependences on source model. Drawing model is referenced on family_table_model<generic_model>.
If model is used in assembly as family table model (instance model) - you can replace this model by new model (with new name) - click on model and select: Edit > Replace... > By Copy (system create a new model independent on source model - independent on family table model).
Open the instance in memory (along with the drawing if needed), go to the generic, delete the instance from the table, save the generic and erase not displayed with the instance and drawing still open. This should make it standalone.
However, if this is in Windchill it may cause you many issues down the road.
Patriot_1776
I recently opened an instance of a family table, I'd made and simply did a "Save a Copy" in Pro/E, and it worked just fine.
