Family Table - Model doesn't update
Greetings,
I’ve set a family table for my assembly. In it, I have one part I want to change and a sub-assembly that changes as well.
The sub-assembly is working perfectly, it changes to what I want with no problems. However, the part doesn’t work. In one instance, I want the part to remain the same and it’s fine. The other one, I want to trade this part for another. Although the verification is a success, I open the instance and the part is still the one from the generic.
This parts I want to change have the same WTpart. Also, this isn’t working for me but a coworker managed to make it correct in a test workspace.
Has this ever happened to you? If so, what did you do? I appreciate any help!
Thank you,
elrafa44Answer
I noticed that by changing the part I want, many other components of the assembly don’t have where to place their relationships. Therefore, my instance wouldn’t be correct.
I replaced all relations with “fix”. It’ll be harder for future changes to be implemented but for now I’ll go with this.
elrafa445-Regular MemberAuthorAnswer
You need to create an interchange assembly.
- create new interchange part
-assemble all of the interchangable parts
-match the references to each other
-in family table you can specify the new part/assembly to be referenced
There's a help tutorial and some YT videos that can help.
