Fatal Error in a drawing when choose axis as a preference
I experienced the following unexplained error. I have a drawing of a part with holes, and when I want to put a note with a leader or create a dimension by selecting the hole axis as the reference, the program gives a fatal error
Moreover, if you make a new hole in this model and select its axis as references, everything works
I think the solution to my question is here (CS273123), but I don't have a valid subscription
(Creo 5.0.4.0)
StephenW
StephenWAnswer
The support article defines it as a bug that was fixed in creo 5.0.0.0. It shouldn't be a problem in 5.0.4.0
No info other than closed with a software fix.
Your issue probably isn't a bug, it's probably a data dependent error, especially since a new hole axis doesn't exhibit the same problem.
StephenW
StephenW23-Emerald IIIAnswer
Thank you!
One more nuance.
If I make a new drawing of this part, and refer to the axis in the drawing, everything works
