Sep 2, 2022 3:50 AM UTC
Fatal Error while accessing an Assembly model
I am using Creo Parametric Release 6.0 and Datecode6.0.3.0
an error is observed while trying to open an assembly model. and this is happening for only one model.
Here are the errors that I faced
Fatal error encountered. A traceback log is written to
    Sep 2, 2022 8:36 PM UTC
    If it is only one model, then most likely it is something in the assembly structure.
    If it is multiple sub-assemblies, be sure each of them can open.
    A traceback can only be resolved by PTC tech support and they will need to have you upload the file to them with all components.
