feature-intersected components not updating
  • February 11, 2016
  • 4 replies
  • 2079 views
I have a quite puzzling problem with assembly level features.
I want to redefine the reference surface of a assembly-level hole with respect to a new surface which will be obtained from an assembly-level extrusion I want to insert (before that hole itself obviously).
The problem is that after I insert that extrusion, and re-open the hole menu to redifine the reference surface, the software still sees the old (out-of-date) surface as the new extrusion had never been there.
Exiting from edit-definition menu, and regenerating, the model goes up-to-date.
I already opened a support case with PTC TS, they initially told me it's a problem of model accuracy (must be absolute and the same for all models involved) --> it seemed to be working initially, but then I re-took the same model, repeated the procedure but didn't work. Re-opened the case, they passed it to R&D department and still no reply arrived to me yet.
Anyone has experienced the same thing and knows what the cause is?
Here below a video of the steps I take:
Video Link : 6699
thanks
bye
Tommaso
did you try to Edit References of the Hole feature (not its definition) ?
MH
tleati12-AmethystAuthor
Hi Martin,
thanks for your reply. I have just tried your suggestion, the correct surface is there and selectable, but a regeneration error comes after. If I then select edit definition, the new reference is with the red dot as it doesn't exist...
Video Link : 6695
bye bye
Tommaso
Hi Tommaso,
I am sorry I have no other idea.
MH
