Features occasionally fail but regen successfully after a redefine
I have a param driven assy. one of the features is an axle that references two planes (basically angle and height in a circle).
the angle plane is driven by a simple equation (dimension pattern, equation driven) to compensate for unequally spaced planes between holes. axle is then ref. pattern.
sometimes the axle feature fails (when we redefine the feat with different nr. of planes, usually unequally spaced), but if i go to quick fix, redefine and just press OK (without changing anything), it regenerates without problems.
any idea what's going on?
i will try to complete an example during the weekend.
