fermeture de Creo2 a la creation d'une nouvelle fonction
I am using Creo Parametric 2.0 M250
Bonjour
je travaille avec Creo.2 et Creo.5
je viens d'installer Creo.7 : bien
j'ai une obligation de travailler sous Creo2
je dois modifier des pièces sous creo2 et impossible de créer une nouvelle fonction , le logiciel plante complètement dés la demande de création
    bardet_phAnswer
    Merci à tous pour vos réponses,
    Effectivement le problème vient du répertoire normalement caché  %utilisateur%\AppData\Local\PTC\Creo...
    création d'un fichier : creo_parametric_customization.ui  qui bug  en mode esquisse.
    fichier supprimé , tout fonctionne parfaitement Creo2 et creo7.
    encore merci
    bonne continuation
    KenFarley
    We had someone long ago with a similar problem. He had installed many versions of the software as time went by and never uninstalled the older versions. I believe the problem was that the older software is trying to load software modules that were replaced by modules of the same name in the newer version of the software. They are not compatible, so Creo 2 crashes. Probably not very nicely.
    I don't know if it is easy to install Creo 2 and Creo 7 at the same time so they do not have troubles. Hopefully someone who has done this will have some ideas. Easiest I can think of is if you have more than one computer so Creo 2 on one, Creo 7 on another?
    Dale_Rosema
    Or you make sure they are running from completely different folders so that they don't overwrite features as noted. When I have done this, I got my VAR to help me load the other versions so that this wouldn't happen. They should be able to help you straighten this out.
    Bonjour
    try following:
    • in File Explorer open %APPDATA% directory and rename PTC sub-directory
    • test Creo 2.0
    bardet_ph1-VisitorAuthorAnswer
    encore merci
    bonne continuation
    Dale_Rosema
    Don't forget to mark your answer (or Martin's) as the correct answer for those who may search on this topic.
