Fill surface disappears when using right-click hide
When I right-click, hide the Fill Surface on the model itself, it is no longer interactable even through the model tree. Conversely when doing the same through the model tree itself instead of the model, it works as expected.
Is this a bug or is there a way to unhide/show the surface that I am not aware of. (I have been resorting to restarting creo)
I realise the right click menus are not visible in the video, however I think the video is clear enough without it as well.
*I am using PTC creo parametric 9.0 student edition
  • in model tree you select feature
  • in graphic window you select quilt by default
see video.
see video.
Oh that's interesting, as I mentioned I am new to using surfaces. Thanks a lot for your continued help and time.
Wishing you a great day,
Ibrahim
