7-Bedrock
December 13, 2019
Flat to screen notes not showing in Creo View
I cannot figure out why flat to screen notes created in Creo Parametric are not showing on the corresponding viewable in Creo View. Measures and tolerances and notes that is attached to geometry, are showing fine just as they where created as combined views in Creo Parametric. Is there any specific setting I miss?
I'm using Creo Parametric 4.0
in case that nobody respond I suggest you to contact PTC Support.
You need to edit the Creo view recipe file and checkmark the option "Planar Annotations"
