Flexible componant with snapshot on drawing
Hello
I see this PTC article: CS50932
Snapshot is not updated in drawing for a flexible component
But PTC says it's article is available for: Creo Parametric 1.0 to 4.0
Anyone know if it's OK for next Creo's version ?
I have Creo 7 and obviously it does not always work
It's a problem because the PTC circumvention is not applicable (make flexible componant in 2 hard componant)
It's ok when you have not much part but it's impossible with a lot of part
it's a shame because the principle of snapshot is very great and light comparatively to Solidwork's configuration Anyone can to help me ?
XDN14-AlexandriteAuthor
I think find a way to get around the problem: but's it's not fully 🤔
In my assembly, i make all the snapshot i need.
After, i make a family table, the snapshot are inherited from master assembly
and i activate the snapshot interest me into instance.
But is not very stable when i have lot off view in my drawing.
Is it possible to call the snapshot in columns of family table.
If it is possible the probleme is then solved
someone knows it ?
7-Bedrock
I have the same request as XDN.
Is there any improvment in Creo8?
Thank you
Sorry , i don't have Creo8, i don't know  if this problem as solved in 8 or 9
Hi @XDN bonjour @dBarbat
The content of the article raises some questions and there is a process for that: did you send an article feedback using the portlet "Something is wrong with the article" or "Was it useful"?
Here is why it is more efficient: it sends your comment directly to the authors of the article who are the better people to address the content of it.
