Apr 22, 2020 3:58 PM UTC
Flexible component drawing
Hello to all,
I created an assembly that contains a flexible component (spring_compression.prt) and I created two snapshots.
In 3d everything is updated correctly when I change the view from one snapshot to another.
In the drawing instead I created two views that recall snapshots but the spring does not update.
It appears as it is in 3d.
What can I do?
I don't want to create a family table because I have more complex mechanisms, with many positions to put in the 2d and they would become too many to manage ..
Attached are the files made with creo 6 and an image.
Thank you,
Matteo.
lascariAnswer
7-Bedrock
Jun 15, 2021 9:43 AM UTC
Matteo
Noi abbiamo risolto creando due envelope nelle configurazioni "molla estesa" e "molla compressa".
Poi abbiamo creato due simp.rep che usano quegli envelope.
Poi nella messa in tavola abbiamo inserito due general view con le due simp.rep.
In questo modo hai nel disegno le due configurazioni (vedi immagine).
Apr 24, 2020 5:47 AM UTC
@Matteo_1987 wrote:
Hello to all,
What can I do?
Thank you,
Matteo.
I cannot unpack your rar file. Please create zip file and upload it.
Apr 24, 2020 4:26 PM UTC
There he is,
ty.
Apr 27, 2020 12:50 PM UTC
@Matteo_1987 wrote:
There he is,
ty.
I think that no model can be in two different states at a given moment. Therefore you cannot display two different snapshots in two different views.
I am sorry I cannot provide "parametric" solution. All I could think of was a stupid solution:
  • activate snapshot 1 in Assembly mode
  • place view in Drawing mode
  • convert view into draft entities
  • repeat the above process for other snapshots
lascari7-BedrockAnswer
7-Bedrock
Matteo
