Flexible component not maintained through flattening in electrical assembly
Article - CS264721 indicates that flattening flexible components in electrical assemblies is not a function available in the software. The article states that it applies to Creo Parametric 2.0-8.0. I am using Creo 10. Is there a workaround? I would like to keep the flexibility, as I typically use it for cable heatshrinks.
