bbrejcha
Flexible Components Assembly for a Clutch Spring
Since all of us are sitting at home itching for something to learn, I thought I would take the lead.  I'll be doing a webinar referencing two youtube videos.   If you take a look and try these out, I will answer questions and give you more tips and tricks.   I will demonstrate the basic use of surfaces and equations with springs to mitigate size relative to their use in the assembly.
Webinar: Flexible Clutch Spring Model with Creo Friday, March 27th 2020 12:00 pm CT
RSVP  https://design-engine.com/webinar-spring/
Bart Brejcha
Design-engine.com
