7-Bedrock
Flexible parameter value column in model tree
need to show a column for flexible parameter value in model tree for multiple occurrences of a part in an assembly.
when i add flexible parameter to tree columns it is showing constant value for all occurrences.
Please see the attached video.
Ty
7-Bedrock
its working fine for solid components, not for bulk material component.
Based on some quick testing, I'm not sure it's possible to make bulk components flexible. Can you describe what you're trying to do with the flexibility? Maybe there's another solution to your problem.
Ty
