Flexible pipe/Tubing
- January 6, 2017
- 0 replies
- 1140 views
I am working on creating the machine which will show the Pneumatic and Hydraulic lines from panel to the other units in the machine. How to create hoses in a effective way, it takes lot of time to create one line of hoses since we have to create the route points by extend and then providing the X,Y,Z dimensions and again editing the route is a big pain or we have to create a datum points using offset co ordinate system to select the route points. Is that any other better way to do it by simply dragging the co-ordinate system to the desired location along the route points. I have to create nearly 40 tube lines which spreads all over the machine.
Appreciate your help
