Frameworks - imperial profiles and metric drawings
I'm troubleshooting some unexpected behaviour with frameworks. My company works in metric, but the steel profiles we use are imperial. Building a weldment with plates and beams, I usually make the plates in our metric template and the beams through whatever frameworks uses to generate the parts. There are no problems until I make the drawing and detail the parts. The plates show metric dimensions just fine, but the beams show imperial values with no unit indication. In the picture attached, the R18.4 and R20.44 should actually be R467.36 and R519.176.
Am I missing some settings that would correct this?
