Generating images from Views
I often need to generate high resolution images for all views of top level assembly. I tried to make a mapkey but it works to produce single image. Here are some issues i got :
1. Even when i use to rember keyboard inputs, it still asks for filename, page size and resolution.. which takes lot of time and interrupts
2. For quite sometime, it stopped taking user inputs at all and accpets defaults. I know i didnt make it that way initially
How can i automatically create images which are named after their view-name with extension jpg and a non defualt resolution of 300? Or at least i can change such defualts which will reduce time for each save as operation?
Any help is appreciated.
Welcome to the forum, Junaid.
I might suggest a different tact. Have you played with animations?
Nice thing about animations is the ability to recall views at intervals, and you can even set display states which really helps in creating presentation "flow".
Animations can be output as images and even force a phororender between frames. The output will be <filename>001, ...002, etc. but the point is, it outputs a series of images and if you have the frame rate in line with the image switching, you got yourself a self-generating presentation sequence.
The other plus is being able to specify the frame size (although there are some bugs at larger frames). You can tune the window for std 3:4 frames or wide screens, etc.
And in the end, you can save the whole series so you can repeat it if there is a design change with a simple recall of the animation sequence.
EngineerJ1-VisitorAuthor
Many thanks. It will do the basic purpose.
However, i would be open/ interested to further explore the issues of mapkeys and defaults.
