GEO TOL will not attach tangent to leader
I am using Creo Parametric Release 10.0 and Datecode10.0.7.0 geometric tolerance jumps off of the witness line when I try to move it. When I create a new geometric tolerance it will not allow placement on tangent to horizontal.
Catalina
Community Manager
Hi ​@vincecatlin
Thank you for your question. 
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Please add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Catalina | PTC Community Manager
7-Bedrock
If this happens in the drawing, check your 3D model. It's highly possible that you show the gtol in 3D and already make it tangential to the dimension. Move it away (not tangential), then go back to the drawing. It should be ok from my experience.
