Jul 21, 2015 1:58 PM UTC
Getting PRO_TK_PICK_ABOVE error on use of Proselect. Can any one explain why.
I am using Proselect in loop to select the model in drawing. and i am getting PRO_TK_PICK_ABOVE error . Can any one explain why.
Manoj
Jul 21, 2015 2:01 PM UTC
From API header files description:
Return Values:
      PRO_TK_NO_ERROR   - The user made a selection, or chose <b>Done</b>.
      PRO_TK_USER_ABORT - The user chose <b>Quit</b>.
      PRO_TK_PICK_ABOVE - Selection was interrupted by a user's pick on
                          any button from above menus.
      PRO_TK_E_DEADLOCK - The Creo Parametric user interface is not prepared
                          to handle this request (because it is blocked by
                          another process such as an OLE container activation).
Alex
mwaghmode1-VisitorAuthor
Jul 21, 2015 2:55 PM UTC
Thanks , but i want why the error is coming.
FV_01
Jul 24, 2015 9:21 PM UTC
please check if you are using uiCmdPrioDefault instead of uiCmdPrioImmediate.
HIH.
Feliks.
