6-Contributor
Got an error while adding relations "Requested filtered table exceeds the number of allowed rows"
Hello Everyone,
We are working on an assembly having lots of sublevels. While creating some relations , when try to "Insert" -> "From List" , it shows the error message "Requested filtered table exceeds the number of allowed rows.Re-edit the filter or cancel."
Please help me to solve this issue.
Regards
You will need to create a custom parameter table filter.
From the ribbon select tools > parameters  then on the right hand side of the parameter window select customize.
After you have created your filter you can go back to the relations window. If you can't see the drop down list for the parameter filter, select edit>show filter
Could you explain step by step with image?
I have this same question. Has anyone figured out how to work around this error message?
I think I just stumbled across my answer... I had gotten as far as creating the filter and could see it and use it under the "Local Parameters" section at the bottom of Relations window. But didn't know how to get parameter added to the relations from there. Tried right clicking, but click must be on a column other than "Owner" which is what I missed previously. Right click -> Insert to Relations
