Graphics Window Display
Esteemed Colleagues,
This problem has been plaguing us for many years with some of our customization.
We are preparing Creo 2 M080 for rollout and it may finally have provided its own solution. I have a call with TS under Toolkit to see about doing this programmatically. There may be another way, which is why I’m appealing to y’all.
Is there a configuration option that will turn these graphics off without also affecting how dimensions are displayed?
Note that the On-Demand Simp Rep: indicates that there is a simplified rep active. This obscures model graphics and can be hidden with the View -> Model Display -> Temporary Shade menu sequence, as can the tolerance table display. The tolerance display (x.x+-0.1…) can be turned off with an environment setting but it also turns off dimension tolerance displays, which is undesirable.
W.C. (Bill) Bowling
Fellow-Engineering Design Process Development
Aerojet Rocketdyne
CAD Services
Office: 818-586-0310
Mobile:805-501-4875
