&harn.run.cond.from.pin.name not work
Hi!
I have problem with the report of the harness parameters in table.
I have set parameters for connector, pins and cripms. But I can not report this. I have the filing, that I can not use all of the parameters shown in the group in my attachment. So I can not create a table with the information from witch Pin to with Pin the wire is going.
If I use the manufacturing tool, he create right table, But this table is dad (it is just text). So any update is not working.
That is way I prefer  to have my own drawing with my own table.
What can be the problem?
Maybe somebody can do this table (I have attached the Creo files)
Thank you in advance!
oullAnswer
Normally the entry port for wire must be linked to a pin then &harn.run.cond.from.pin.name will fil in the from/to pin name in the repeat region Table As described in Article - CS133154
https://www.ptc.com/en/support/article/CS133154
Please refer to Creo Help about how To Assign an Entry Port to a Pin Number :
http://support.ptc.com/help//creo/creo_pma/usascii/index.html#page/electrical_design/cable/About_Entry_Ports.html
http://support.ptc.com/help//creo/creo_pma/r8.0/usascii/index.html#page/electrical_design/cable/About_Entry_Ports.html
and to this video Demo at:
https://support.ptc.com/images/cs/articles/2018/09/1536220508kdQi/demo.mp4
Regards
Mustapha
oull16-PearlAnswer
Regards
Mustapha
