Harness manufacturing
- 4 replies
- 4678 views
- Translate All
i'm new on CREO (3 month). new job new company.
i used to work on different software to create 3D harnesses.
i have an issue today regarding Harness Mfg. we just got the licence
i try to flatten simple harness. it work (sometime) but when i want to use a component
to route my harness sometime it will work and sometime i got the following message:
Unsupported Axial Topology
when i remove the component from the path it will be ok, but i use the same component
somewhere else and it is working fine so i don't understand what is happening.
i think the part i use to route the wire is created properly as it is working fine somewhere else
if someone has an idea i will appreciate.
Ced1
