Has anyone successfully used Creo MBD semantic PMI for automated CMM programming
I am using Creo Parametric Release 10.0 and Datecode10.0.4.0
We are evaluating the purchase of a Coordinate Measuring Machine (CMM) that can automatically generate inspection programs from a 3D CAD model created in Creo Parametric using Model-Based Definition (MBD)
Our objective is for the CMM software to read the PMI/MBD information directly from the model and automatically create the inspection routine without manual programming
During tests with a Mitutoyo supplier, we found that:
Several dimensions and tolerances were not recognized by the inspection software
Some annotations were imported as graphical annotations instead of semantic PMI
Consequently, not all inspection characteristics could be used for automatic program generation
We would like to know:Is a specific Creo module, configuration, or export format required to ensure PMI data is correctly interpreted by CMM software? What is the recommended workflow for transferring MBD/PMI data from Creo to inspection systems? Are certain CMM brands or inspection software solutions more compatible with Creo MBD data? Is any additional Creo functionality or licensing required to export semantic PMI correctly?
Any guidance or best practices would be apprecia
