Healing imported data (iges)
- April 20, 2010
- 1 reply
- 633 views
You guys are the best so here goes ...
I am having trouble with this RJ45 connector (iges) I received from a supplier. Their appears to be a few small edges that need to be healed in order for it tobecome a solid. I'm running WF2.0 and don't have access to Import Data Doctor (at least I don't think I do). Is there a way to fix this in WF2.0? I don't need it to be parametric so ifsomeone can heal it for me and send me back a STEP or neutral file that would work also.
I have other larger more complicated files in the same condition and I need to find the best approach. If it means getting into WF4.0 or even 5.0, I'll put my efforts there and export/import back into 2.0. If there is a way to get it done in WF2.0 even better.
TIA
