HEEEELP! How to edit an .igs file on PTC Creo?
  • July 24, 2012
  • 214 replies
  • 78690 views
I am using PTC Creo Parametric 2.0 and I really need to edit an .igs file!
I can import it and open it but i cannot modify the geometry or like modify the original sketch...I am just able to move the parts.
What I need to do is to create another sketch over the geometry and the 3D I import, cause I need to draw and add another "piece" to it.
If anyone knows how to do it please reply!
Thanks in advance
Best answer by joates
Thanks for all the feedback. This was my first ever post and I’ve had some helpful replied and support. All in all its been a good vent for some of my frustrations.. to be constructive on some of the irritations:
- suggestions/feedback...? I could not find an official sections/feedback e-mail or reply page.
- 2D control drawings dimensions: when it comes to dimensions it now takes 4 clicks plus mouse movements/hovering to move a dim around and into a non default position. rather than 2 and a bit of hovering.
This may sound like a small thing to get pissed off about, but it made my time to complete my end of project tasks/work twice as long! And its not like it was not good before... Time is money and I don’t like spending it on what should be old rope.
- Open system window > purge (working directory): Its very helpful to purge your working directories when you got big asms and many components. Stops your drive filling up quick. Only accessible through Creo 2.0 when NO files are open.
you guys are scaring me,ultimately developers will have that surface hardening effect,just like what happened to Internet Explorer,no matter how much people bitch about it ,they are so self motivated or surface hardened that they keep making release after release after release without improvement in basic functionality.
In Inventor, we had poetry, about WHY oh WHY my cerefully organized menus flew around on the screen, at will.
In Creo we have magic: Sometimes things work, that normaly doesnt work for me.... and WHEN they work, its like magic : i still dont know, why it works today, or even what secret mouse movement made it work.
I started using Pro/E since about version 12, which was about 20 years ago. In general, every few upgrades, they add a few nuggets that are cool, while completely scrambling the UI for what is essentially no reason. Why do I think it's for no reason? Because you have to re-locate all your buttons, re-make mapkeys, learn new config options, etc., all to do what is essentially 95% the same work you did before the upgrade. A few years later, they change it again. It's quite annoying.
I think that certain people at PTC must justify their job by changing things so it seems like they are making things better. But mainly they are just making things different. All the while, thousands of hours are wasted around the world as people struggle to adapt.
Now that I am on Creo, I see absolutely no difference for what I do on a daily basis. I don't use the new features. I just spend time trying to learn where the old features have been moved. Thanks, PTC!
Oh, and while the graphics quality of everything in the world just gets better and better, Creo's graphics have stayed the same or gotten worse. I have lots of graphics issues on a PTC-supported set-up and Creo support has viewed my screen and verified it's working properly, glitches and all.
I will adapt and get back to full speed in a few months, but I feel like all the time spent adapting was a waste.
Patriot_1776
EXACTLY what I've been saying Larry.
Funny how no one likes circles represented as hexegons, huh
Most of the issues I've seen on this thread concern the interface. Rest assured, in the CAD world, this is universal. The marketing department runs all the CAD companies, AutoDesk, Dassault (SolidWorks), etc. They insist on a new release every year, and there MUST be 6000 changes. Usually the engineers only have a couple dozen things to address, so they fill in the rest with change just to be changing. The user interface is particularly vulnerable, as that's all the marketers see (they usually have no idea and no concern how the software operates). The end result is a user interface that must be re-learned once a year, with no regard to the agony this causes the user. The CAD companies can do this because the software is bought by purchasers who also have no idea and no concern how the software operates. As long as it looks different, the marketers can say it's "new and improved", and as long as it looks different the purchasers will believe it. Accept it -- it's the business model.
Other places to register your rants:
Ribbon Angst
http://communities.ptc.com/groups/wf5-ribbon-angst
Allow the status bar to be moved to the top of the Creo window
http://communities.ptc.com/ideas/1327
Remove the Ribbon
http://communities.ptc.com/ideas/2359
OK....
I have now been working with SolidWorks and Creo 2.0 for 9 months.
I'm absolutely up to speed on SolidWorks, which was new to me when I started.
Continuing using Creo 2.0 and PDMLink was just a bonus as I see it now.
PTC can learn something about UI from SW, but SW can learn something about robustness and features from Creo.
In my opinion they cover 2 different approaches to CAD which necessarily don't have to rule the other one out.
I love the way sketch behave in Creo, and SW is just as nasty when it comes to references as Creo.
Assemblies in Creo are much more intuitive, especially when something goes wrong!
You can constrain an assembly in SW so that NOBODY can grasp the idea on how and why things are as they are:) - I've seen examples from colleagues that gave me a lot more grey hairs than Creo ever have.
Just to make even more fun within the next ½ year or so we're all moving to Siemens NX 9.
That will give some fun!
Have a nice day!
Preben
StephenW
Great review Preben.
Good luck on NX. I have heard good/bad things about it as well.
Ohh my god.
Just found another reason to really HATE creo.
The way it handles changes in config.pro options.
I have a set the option save display to NO.
So every time i open a drawing MADE with the option set to YES.
It does NOTHING.
IT opens the drawing with UN updated Views, even though my Config.pro options states i would like it to update.
SO now i have to update EVERY fu**ing drawing manually anyway, to be shure of its state.
Once updated, it WILL remember the new setting.
WTF
Now the thing that REALLY gets me, is the nod of silent approval i get from the "old" wf brigade.
They are actually USED to this kind of behavior ?????
Power system my arse.
Its NOT power, to have a system that CANNOT FOLLOW options.
Now dont get me wrong. I understand that the system does as its told.
I just cant believe the choises.. The lack of logik.. That makes this the preferred way to respect config settings.
This is EXCATLY like your car changing to reverse as you enter youre driveway, just because you reversed out of it last time you were here.
The RELLY fun part about this, is that ANYWHERE it WOULD be bennificial, to remember settings.
Like f. instance the hole manager, remembering the last hole, the constraint manager, remebering what panes to keep open and so on.
THERE Creo CANT remember.
LOOOOOL
This system is a JOKE
We just jumped from WF4 to Creo 2.0. I had tested WF5 and Creo 1.0 and knew I would hate this for one simple reason, the RIBBON! I have yet to see anyone that likes it. I hated the ribbon when Microsoft started using and I still hate it. Im all for change but when the only change is just to make things looks pretty I could give a rip about pretty gui. There is some new functionality with Creo I give credit for that. But productivity is down due to menu system. We have requested new features for years to a deaf ear at PTC, what do we get? Something we did not need or want, a ribbon bar. Whew, I feel better now.
Patriot_1776
Agreed 1000%. I have to listen to my new ex-Solidquirks Engineers complain about it constantly, how much "faster" SW is, blahblahblah. And then there's all the endless Windchill problems we have......
Anybody having a lot of crashing issues with Creo 2.0 M090?
Plan To Crash (PTC) Creo 2.0 happens more often than it should...
Hi Marshall,
Have you tried updating the video driver?
Hi Chuck,
We have upgraded the driver above what Dell has available.
I see that video cards and drivers are a focal point to many threads on this site as a problem solver.
My workstation is a fully powered server based unit.
Working through a T1 line to our main file server 600 miles away using Windchill is probably the real head banging crash generation source.
Lots of crashes!
I''ve been prettty much a lurker and came across this thread. I'd like to chime in with a few of my thoughts if I may.
Been a PTC customer now for almost 25 years (user and administrator) and have seen many progressions/evolutions with their products. I've also used/administered SolidWorks since 1997.
Transitioning from Pro/E in the early days to Wildfire 1.0 was a nightmare. Icons?? An unmitigated disaster. We were constantly fighting it all the way thru WF3 and decided to evaluate SolidWorks. Needless to say, we couldn't even get thru 1/2 of the evaluation due to SW crashing and spitting on our complex assemblies (helix's). Intralink was also a far better option to manage the data then what SW was offering.
Bottom line was that although the WF interface sucked, it just worked. How much time would we save with a GUI if the system keeps crashing? No brainer.
We upgraded from Intralink to Windchill in 2009 and have to say it's been nothing but exemplary from a performance standpoint. Sure the interface is "web based" and a maybe a little clunky, but it works well and the integration/speed with Creo is lightning quick. Access across the WAN without replicators is no problem. No other CAD vendor can globally manage their data as efficiently as Windchill can and that's a fact.
Fast forward to 2012. Creo 2.0 is deployed to my user base and 95% of them are extremely happy with it. It never crashes, most of the commands can be accessed with right mouse clicks while the interface is getting more consistant. Is it perfect? Not by a long shot. But it works.
Last year because of corporate acquisitions of some small companies (using SolidWorks) I was approached by senior management to perform another Solidworks evaluation. In summary:
  • SW still has issues with large assemblies
  • Dassault is moving away from the current Parasolid kernel with V6 which means that were will be no UPWARD file compatibility
  • SW V6 (catia V6) kernel is 100% incompatible with Windchill.
  • Creo 3 will accomodate SolidWorks files in their native format (game changer)
It's my personal belief that for many years, PTC spent much of their development $$ on Windchill and let Pro/E slide. This is now visibly changing as a lot of new technology will be incorporated into Creo 3. Dassault has been spending their $$ on V6 which is why SW has not had any major functionality upgrades since 2008.
Creo 5 as someone had posted earlier, may finally be the panacea that we've been waiting for.
Sorry for the length of this post. Cheers!
Awesome post very close to my experience... You are dead on correct. I spent 5 years with a company running Pro/E and Catia simultaneously... there is no comparison in overall customer satisfaction, technical support, applications and future of the business.
Thanks Carl.
I do think that things have really improved at PTC in the last 5 years, one of note is the Upgrade Advisor. Managing multi-CAD environments can be challenging which is why I'm highly anticipating Creo 3.0.
Every software package out there has a fan base as well as their detractors. Dassault is walking a fine line right now and has really put themselves in a difficult position.
I'm in the process of switching to Creo 2.0, after 1 1/2 years on Pro-E 5.0 and 20 years of AutoCad. So far I think
that Creo 2.0 is going to be easier to use, more user friendly, than ProE 5.0. Maybe its my backgound with AutoCad but I'm liking the change so far. I guess after a few months I'll see if I really like Creo 2.0 or not.
Having used Pro/E 18 many moons ago it has came on massively over the years to give us WF and now has taken further leaps to bring us Creo.
I have used the right hand menu manager which newer users won't be familiar with. I found it easy to use but now when its nearly gone (it still pops up now and again for some commands) I realised I hated it and how slow it was compared to the current icon based interface. PTC couldn't keep the menu manager...it wasn't scaleable and needed to be replaced to embrace current Windows standards in user interfaces.
I have worked with a few engineers who have hated Pro/E or Creo. In my opinion there is no real basis to the hatred. I usually put it down to poor training and poor expectation management of the software. They have been duped into believing that after a week training in a classroom that it can do everything they want in half the time.
Generally out the box PTC training is a very broad - bespoke customer focused training could help but would inevitably cost extra.
Usually when I was called upon to help my less experienced Pro/E user colleagues when they hit a roadblock I could show them how to do something and it the comment was usually 'I didn't know it could do that' or 'that was easier than I thought it was going to be'. Some people have a pre-conceived notion that the software is complicated and unfriendly so that mindset inhibits users from exploring the software because they think its too big and scary.
It like learning to drive...you had the lessons to learn the basic operation and rules, get to a decent level to pass a test but you don't actually start learning properly and get competent until you go out in the road yourself and get experience!
And every day you are on the road you learn more and more until things become second nature,
That is a bit what learning Pro/E & Creo is like. How long that journey is to being competent varies massively with the user and the situation/company they work in
I can visualize the analogy of using PTC software to the driving of a car:
In this instance, the car is an early 2000's model Pontiac Sunfire filled with aftermarket parts plucked from Ferarri, Audi, and Saturn.
Most of it just doesn't seem like it fits together or was created by engineers operating from the same company. Some features look brand new and function well, while other features are obviously plucked from another software or company that no longer exists.
It visually looks out of date, and has so many bells and whistles that truly have no necessity for ultimate function. If you know how to drive it, you can make it go extremely fast, but inevitably something will break and most people driving it will just crash.
You can't resell it because no one wants it, so you're stuck with it even though you know no one will be driving it in the future.
Bartholomew,
Thanks for your great contribution.
I feel like a crash test dummy at the end of the day, run hard and put away wet...
Yugo comes to mind.
