Aug 11, 2022 8:02 AM UTC
Help getting this plotted correctly
I'm trying to incorporate a cycloid (standard, not epi-) into a design I'm working on. I tried to generate the appropriate curve using the equation from curve tool, but it only returned a very slight curve. I verified my equations using MATLAB. Pictures and equations are provided below:
x(t) = r(t-sin(t))
y(t) = r(1-cos(t))
where t is some angle and r is the radius of the rolling circle tracing the cycloid.
Any help would be greatly appreciated!
KenFarley
KenFarleyAnswer
Aug 11, 2022 10:51 AM UTC
The problem is that the equations as you have them are assuming the angle being evaluated is in radians.
If you are inputting the angles in degrees (0 - 360), you'll get a very large "X" result.
To correct this, again assuming you are setting "t" to be 0 to 360 degrees, the equations should be:
x = 1 * ( pi * t / 180 - sin(t) )
y = 1 * ( 1 - cos(t) )
This seems to give the desired curve.
KenFarley
KenFarley21-Topaz IIAnswer
Aug 11, 2022 11:01 AM UTC
if you set From = 0 and To = 360 for curve from equations then use following equations.
x=100*(t * PI() / 180 - sin(t))
y=100*(1-cos(t))
z=0
Creo uses angle values in degrees, because of this sin(t) and cos(t) is used.
t * PI() / 180 converts angle value to radians to satisfy cycloid definition.
