Help with Swept Blend
- 7 replies
- 5773 views
- Translate All
Hey all, first post here. I am trying to use the swept blend feature to remove material as shown below. I am using a start sketch and an end sketch to drive the geometry of the swept blend and I am using a curve that I created by points (many!) on the outside surface of the original geometry. The issue that I am having is the swept blend is not working very well and leaving a lot of excess material. Also, it is not following my curve very well. I tried using two trajectories but I do not think that is allowed. I have been struggling with this for may days now so any help is appreciated. The end goal is to remove material from the center section and have it tapered on the edges at like a 45* angle, which you can see from sketch.
