Help writing a relation for a bend
- 5 replies
- 2380 views
- Translate All
I cant' figure out the correct equation to drive the wing outside diameter and wing inside diameter for this part.
(I will attach the part file)
Image 1 - This is the part bent. The part wings should be fitting into the vertical surface walls.
Image 2 - Just for a visual reference.
Image 3 - View showing that the bent wing is falling outside of the inside and outside radius. (It should be inside of them)
Image 4 - View showing the sketch and relations driving the part.
I'm open to other methods as long as I can flatten it and that the flat pattern drawing will let me place dimensions on the arcs.
Thank you for your help
