hiding only a feature in a simple rep
Can we  hide only a feature, eg ( a revolved hole in an exploded view in a shaft in an new representation.)
because  in simple rep it allows only part not feature.
plz help me
Regards
Kabilan S
2-Explorer
You can create a simplified rep in the part and then substitute that part rep in the assembly simplified rep.
Is it possible to supress a feature that is created in an assembly?
For example: two plates with a hole will be aligned and welded together. In the assembly a new hole feature is created because the hole will be drilled with a larger diameter after welding.
I would like to export a simplified rep of the assembly containing only these two plates with only the original holes and not the larger hole that was created in the assembly.
It seems Im not able to suppress features of an assembly simplified rep.
Any suggestions other than supressing the hole in the assembly?
Did you ever figure this out?  I'm trying to do a similar thing.
