Hiding status with parameters
In assembly is it possible to hide and unhide parts, layers etc. with formulas and parameters ?
Thanks in advance
requested functionality is not available.
Try using combined states.
You can use rule-based simplified reps to exclude/include parts with/by parameters. I'm not sure if this meets your need but it's pretty useful and easy to set up.
https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/assembly/asm/To_Create_Simpli_Represens_Using_Defin.html#
does this functionality need ASSEMBLY module?
