Hole annotation cosmetic thread - How to edit ?
Good morning,
I'm having a similar issue, the thread note that you are seeing is a note of a cosmetic thread,
In the holes made with standard hole
i can apply the note that i would from the .hol file but in the hole made with cosmetic thread i'm not able to understand from where it's taken and i can't edit.
Even if in the cosmetic hole thread i'm selecting the same library of the standard hole with the "right " note i'm not able to obtain the result this i want.
any suggestion?
Thanks!
Reference topic: https://community.ptc.com/t5/3D-Part-Assembly-Design/Cosmetic-Thread-Class-Issue-Creo-5-0/m-p/612900#M65730
Catalina
Community Manager
Hi @PANNA_PANNA
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
Dear @Catalina,
i haven't received an answer regarding this post, by chance do you have someone from "official creo assistance " that can help?
Best regards
Catalina
Community Manager
Hi @PANNA_PANNA,
Please feel free to open a support case here: https://www.ptc.com/en/support/
You will be receiving support from PTC tech support directly.
Hope this helps!
Best regards,
