3-Newcomer
November 11, 2024
Hole note dimension Metric to Imperial in drawing
I am working on generating a imperial drawing for a part that was designed using metric standards and the Model properties use mm as the base unit. The drawing is using dual dimensioning SECONDARY to allow me to dimension in inches. However the part also has several threaded holes that have hole notes generated. This means that the hole and thread depth are using the mm from the model when bringing it into the drawing (so instead of 1in depth the note looks to appear as if it had 25.4in depth). Is there a way to make the hole note that gets pulled in to use the secondary dimensions of inches that the drawing is using so that it matches the units of the drawing without setting the model properties to inches and updating the note in the model.
Community Moderator
November 15, 2024
Hi @PO_11905040,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
I am having the same issue.
I need a way to have the dual dimensions in the note properties for a &THREAD_DEPTH and &DRILL_DEPTH as any other dimension is dual (inch [mm])
