hole table splitting
I am using Creo Parametric Release 7.0 and Datecode7.0.7.0
how can i divide a hole table?? there is the possibility to paginate it as i can do with repeat regions??
lbianconeAnswer
i know, but the table i already have with a single segment, does not change if i modify rows number.
if i delete it, and create a 30 rows holes tabe, then i can change the rows number.
just this litte bug happen, but the solution is perfect
Dale_Rosema
I am using Creo 4.0, so it should also be available in 7.0
You can set the number of rows and then drag/move each section onto the page you want.
These are broken up, but on the same page.
Dale
lbiancone10-MarbleAuthor
hi.
thank you so much..
i've tried but on an already create hole table.
it seems to work only for the table you are creating.
thanks again
Dale_Rosema
I hadn't seen this before, but it worked.
Then select the table (the one peeking beneath the pop-up)
Changed is to 20, updated. Now I have (4) table with a maximum 20 rows each that I can move around.
