Jun 20, 2022 12:12 PM UTC
How can I add a hole driven by a relation?
I'm trying to create holes in a part that depends on its lenght. If the part has a lenght >= than 2000mm the hole should appear with a certain distance from the middle. If it's <= than 1000mm the holes shouldn't appear.
How can I do that? I tried to write it as an IF condition but the holes are appearing in both cases.
Jun 20, 2022 12:38 PM UTC
You mean you created a parameter, relations and put an IF statement in ProProgram?
Do you have a model to attach to the case? it will clarify your request.
TomU
Jun 20, 2022 6:05 PM UTC
Technically the extra parameter is not required.  The Pro/Program IF statement just needs to reference the length dimension.
Creo 7.0 sample part attached.
Jun 20, 2022 2:05 PM UTC
please create Creo files for testing purposes, pack them into single zip file and upload this zip file.
