11-Garnet
Nov 27, 2016 3:16 AM UTC
How can I add H parameter in th sheetmetal
It has the default parameter in the Creo sheetmetal. (Example : R is radius , T is material thickness)
But I need to add the parameter that is H. (H is Height)
Refer the picture
How can I add the H in the Sheetmetal Bend Table
Because I have the formula that use the H and I don't know how can I set it.
When I was bending it (the Z form sheetmetal) twice , the developed length was wrong.
I Need to use our formula , including H , to compute the developed length is correct.
Please help me add the H in the sheetmetal
Thank you for your reply
My English isn't very good, please don't mind.
Dec 1, 2016 6:04 PM UTC
I am sorry, but I don't understand. You need to add a model parameter H? To where?
Dec 1, 2016 6:51 PM UTC
The flat pattern depends on your bend radii and material thickness. The offset height is just added material to get the final length.
The software will handle that value no matter how you input it.
Your model does not show radii for the bends, but square corners. That will not work for the flat pattern generation routines.
Redesign the part with proper bend radii and then recalculate the flat pattern. If the flat length is still wrong, adjust the Y-factor (K-factor) for the stretching of the forming operation.
There are many documents that explain this. I like the article by Olaf Diegel called Bendwork. It is a downloadable PDF on the web.
yhuang-211-GarnetAuthor
11-Garnet
Dec 2, 2016 3:33 AM UTC
Hi, Ben Loosli & Tomas Loun
Thank you for your replay.
Maybe I need to look for other method.
Because The offset is make once. It's not bending twice.
Their manufacturing methods are different
So the bend formula is not suitable for the offset.
I found that Creo couldn't have any function for sheetmetal offset so that it couldn't define H parameter.
Thank you
I will try other method
Dec 2, 2016 2:44 PM UTC
The offset being made as 2 bending operations or a single die press should not substantially alter the flat pattern length. You still need to account for the stretching of the material through the bends.
You may need to adjust your K-factor value for the software to get you the desired flat length, but that should be easy with a few trial parts.
11-Garnet
Dec 6, 2016 12:58 AM UTC
Thank you
I will try K-factor or bend table.
