Nov 25, 2016 7:20 AM UTC
How can I change font size for tolerance?
How can I change font size for tolerance in drawing? In the same drawing I have two different font sizes and I don't know how to fix it.
P.S. Drawing and model were made in Wildfire 4 or 5, but now I have Creo 3.
Nov 25, 2016 1:47 PM UTC
your situation is strange. I always thought, that tolerance display cannot be set individually.
Tolerance display is driven by following drawing configuration options, their default value is STANDARD
tol_text_height_factor
tol_text_width_factor
Suggestion: Update drawing using commands from Review tab.
MH
Dec 7, 2016 4:30 PM UTC
Hi, sorry for late response, but I'm very busy and this problem is the smalest from what I have.
I tried to regenerate, update sheets, draft, dawing view, tables, but it's not working.
Tolerance display I have set on standard value.
Any suggestions?
Dec 7, 2016 8:02 PM UTC
Sorry, no other ideas.
MH
