Oct 12, 2015 12:33 PM UTC
How can we identify C0, C1, and C2 continuity condition in this attached product?
How can identify C0, C1, and C2 continuity condition in this product?
Which is the best analysis tool for analysis surface?
18-Opal
Oct 12, 2015 6:50 PM UTC
Hi Vishal,
Take a look at this You Tube video, I believe you should be able to select a surface when you are performing the Curvature Analysis.
Curvature Continuity
I hope this helps some or gets you pointed in the right direction.
Amit
vpatel-41-VisitorAuthor
Oct 13, 2015 7:33 AM UTC
Thanks Amit.
I have understood in curve. How can i check the same in Surface? My concept is not crystal clear in the surface.
