How could I set the size of the Elements Direct Model's Bom
I have three flat model of the sheetmetal that needs to output the Bom that can seen largest Length x width x high,beacuse the factory needs to cut them from their size in the Bom.
Their largest Length x width x high of the parameter be change with the models in the Bom.
How could I set their parametric of the largest Length x width x high to the Bom ?
Do you have similar the LISP that I can be revise? ?
Thanks for your help, you do gave me a big favor
