Patriot_1776
How do I get rid of that @!%#$%@%^# annoying "Keyboard Shortcut Conflict" pop-up????
This "Keyboard Shortcut Conflict" pop-up in Creo 4 makes me want to throw things.  I checked and I wasn't able to find any way to get rid of this stupid $#&*^.  Any ideas?
do you mean that even when clicking Use this shortcut for mapkeys > OK, when you type "x", the menu pops back?
add following option into config.pro file ... it looks like it turns system single character shortcuts off.
enable_single_char_keybrd_short no
Also you can follow File > Options > Customize > Keyboard Shortcuts > Category: All Modes,
remove unwanted shortcuts and export settings into ui file for later usage.
Dale_Rosema
Similar type of rant:
https://community.ptc.com/t5/System-Administration/Mapkey-Shortcut-Key-conflicts/m-p/568901
One of the biggest pains is the one key short cuts which eliminates any mapkey starting with that one key.
... by the way, PTC is here to "help you".
Patriot_1776
I tried the setting Martin suggested and it didn't work.  I was able to "Remove All Conflicts With Mapkeys", but it's still a pain.  I don't want that warning to ever come up in the first place.
Dale_Rosema
What's to say they won't help us more and give us more keyboard short-cuts that conflict with our re-written mapkeys.
Patriot_1776
Oh, they will.  It's for our own good you know...they know what's best for us....  LOL
I think one of the main problems is that they've gone to a global, network-based install, so, there ARE no local config.pro and customization.ui files except the ones I have.  And those only overwrite SOME things.  Fo instance, they use the worthless "default" layer scheme, and so I now get new layers popping up whenever I create a feature....and then I'm stuck deleting the layers time after time.  To my knowledge, there is no "setting" to turn off that garbage, except in the config.pro file that resides on a network I don't (and shouldn't) have modify access to.  The Creo 3 install had local copies so I was able to edit out what I needed to to prevent these issues.  So, I've pestered IT for a "custom" install, and hopefully that should cure all or a lot of these problems.
