20-Turquoise
January 15, 2013
How do I plot a drawing to a postscript file using jlink?
  • January 15, 2013
  • 2 replies
  • 1254 views
Wildfire 5.0 M170
I am looking for some example jlink code that will print/plot a drawing to a postscript file.
The following 2 links show examples for creating a pdf export:but I can't seem to find anything for creating a postscript file.
ModelDescriptor descr = pfcModel.ModelDescriptor_Create(ModelType.MDL_DRAWING, partNumber, null);
Model dwg = session.RetrieveModel(descr);
Window window = session.CreateModelWindow(dwg);
dwg.Display();//This part works because the drawing is opened and displayed
PrinterInstructions pi = pfcExport.PrinterInstructions_Create();
PrintPrinterOption po = pfcExport.PrintPrinterOption_Create();
po.SetFileName(partNumber);
po.SetPrinterType("postscript");
po.SetPenTable("stdps.pnt");
po.SetSaveToFile(true);
po.SetSendToPrinter(false);
pi.SetPrinterOption(po);
dwg.Export(partNumber, pi);//ProEngineer crashes when executing this statement
The "abc" drawing is opened and displayed however the Pro/Engineer session crashes when executing dwg.Export(). If I comment that out the session does not crash.
I have no idea if what I am trying is even close to what is correct. Does anybody have any hints to get me started?
Try to use full path for both SetFileName() and SetPenTable() methods.
There might be useful information in any exception thrown from the application as well.
/Bjarne
20-Turquoise
February 15, 2013
Updates on this question. I opened a case with PTC which resulted in 2 new articles in their
Knowledge Base and some key word additions to 2 existing articles so they are more likely to be
found when searching. These are good articles with that also contain the most important items: code
examples
The list of articles follows. The last 2 are new and the first 2 were already created when I was
having this issue.
  * CS78845 <">https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS78845>
      o How to display retrieved models in a new window through JLink for Creo Parametric
  * CS95315 <">https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS95315>
      o While printing drawing models, calling Model.Export() on a drawing in inactive window fails
        with exception "pfcExceptions::XToolkitBadInputs" in JLink for Creo Parametric
  * CS115415 <">https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS115415>
      o Model.Export() randomly throws XToolkitGeneralError exception on every other drawing when
        used in a loop to plot multiple drawing files through a synchronous *JLink* application for
        Creo Parametric. <">https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS115415>
  * CS111626 <">https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS111626>
      o Example code to plot drawing files to *POSTSCRIPT* through *JLink* for Creo Parametric
