Nov 20, 2013 11:08 AM UTC
How do I reset a driving dimension to default dimension
In a 3D model, the dimension may be changed to a driving dimension by the right button.
May the driving dimension be changed back to a default dimension.
POBang
Nov 20, 2013 1:15 PM UTC
Per Olav,
when you modify model by mistake, you can try Undo command (CTRL+Z). Also you can erase current model from session and retrieve its previously saved version.
Martin Hanak
pbang1-VisitorAuthor
Nov 20, 2013 3:14 PM UTC
Thanks.
I know about when in memory. The problem is on checked in models. You may not want the dimension like driving anymore.
POBang
