How do I rotate an object in a creo drawing?
Hello everyone,
I have my front view set up in the drawing, but I want to rotate it. About an axis or a feature, either way. How would I accomplish that?
Mahesh_Sharma
22-Sapphire I
May 27, 2015
Select View > Right click > Properties.
Mahesh_Sharma
22-Sapphire I
May 27, 2015
Purva,
You can try using View orientation in view properties, possibly View orientation > Angle will help you.
pjuvekar1-VisitorAuthor
Hi Mahesh,
I cannot seem to find the Angle option. Under view, there's view>orientation. I can't find the angle command. Could you help me with that? Thanks a ton!
select your view you wish to re-orient and RMB > properties
your options become available
Hi Mahesh,
I apologize for not marking the correct answer earlier. The answers in the this post definitely helped me, thanks to you and Ron St. Pierre!
