how do I set up FEA on a brake disc in order to find out the stresses involved and if the disc will fail or not?
  • November 22, 2016
  • 0 replies
  • 766 views
Trying to conduct FEA on a brake disc in order to see if the design will be able to hold up to the stresses its going to be under, been trying for a while now with a range of different set up. the latest way is fixing the disc on the hole and applying a force on the brake pads while (force of the disc turning) while having a clamping for applied to the pad in order to clamp onto the disc. Which ever way I've tried it hast worked and really looking for some help.
Any advise or help would be much appreciated
Regards
James
