How do I stop it from creating this plate when starting a new part?
Thank you!
kdirth
If that feature is in every new part, it is in your start part.  You need to remove it from the start part.
It is very likely a feature in your start part.
In case you don't know where your start part is located, check the following config option:
template_solidpart
If the new part is sheetmetal:
template_sheetmetalpart
Check this link for more details:
Configuration Options for Object Templates (ptc.com)
