How do you hyperlink a cell in a table in Creo 3.0?
We use hyperlinks a lot where I work in our drawings and we used to be able to hyperlink the cells in our tables but it's not giving us the option now that we upgraded to Creo 3.0. How can we do that without creating a note and putting it over the blank cell?
As a work around, You can generate the note with hyperlink outside of the table, highlight that note CTRL+C for copy. After doing that you can click in the cell of the table, and CTRL+V to paste. Not as easy as just selecting the text in the table and hitting hyperlink, but that is all I can find at this point to work unless there are some hidden configs we are missing.
Dale_Rosema
Ryan Kelley‌
This should be moved to the Creo section.
Thanks, Dale Rosema‌, I've moved this discussion into our PTC Creo‌ product community.
