How export Creo Simulation results in word format?
  • March 22, 2012
  • 7 replies
  • 5902 views
What information are you needing to export to word format?
I just want to output entire report, without the images, as word document.
This option is available in ANSYS, Cosmos and SolidWorks simulation, and it very convenient, and I wonder how to do it in Creo Simulation.
I'm assuming you don't want the stress of every element and the displacement of every node in your report...
Have you looked at the .rpt file, in the results directory? This contains a summary of all the measures (both default and user created) for each loadcase, along with mass and some other information.
Load Set: LoadSet1: DIFF_CROSSPIN
Resultant Load on Model:
in global X direction: 1.537063e-10
in global Y direction: 6.506531e-11
in global Z direction: -6.850000e+04
Measures:
max_beam_bending: 0.000000e+00
max_beam_tensile: 0.000000e+00
max_beam_torsion: 0.000000e+00
max_beam_total: 0.000000e+00
max_disp_mag: 1.993774e-01
max_disp_x: -9.543571e-03
max_disp_y: 1.238497e-01
max_disp_z: -1.992739e-01
max_prin_mag: 1.988448e+03
max_rot_mag: 1.174678e-02
max_rot_x: 1.174678e-02
max_rot_y: -3.192178e-07
max_rot_z: 1.388033e-06
max_stress_prin: 1.988448e+03
max_stress_vm: 1.874867e+03
max_stress_xx: -7.584970e+02
max_stress_xy: 3.706242e+02
max_stress_xz: -3.468644e+02
max_stress_yy: 1.825042e+03
max_stress_yz: 8.407475e+02
max_stress_zz: -9.807174e+02
min_stress_prin: -1.509258e+03
strain_energy: 6.077567e+03
I want to say something ,but i just learn to windchill and .... 好想发个哭的表情
3-Newcomer
October 31, 2014
In the menu of the "Analyses and Design studies" window select "run" and then "settings". By default the output format is set to "binary", change this to "ASCII" and you get your full output in readable text which you can read with word. Will be a long document though.......
Victor
