Nov 4, 2024 5:35 PM UTC
How to add a parameter in a drawing with source as Windchill
I'm creating a new drawing template in Creo 9.0.7.0 for a project. I want to add a parameter to capture the 'released on' & 'released by' values. But it should be sourced from Windchill, not user defined. How we can do this.
KenFarley
Nov 4, 2024 5:56 PM UTC
Sounds like you need to set the parameters in WIndchill. Something that has to be configured by your administrator, I guess.
Using the parameters on a drawing works automatically if you *always* have a particular parameter in your part and assembly files. Otherwise, if you start a drawing that needs a parameter value for one of the text fields, and that parameter doesn't exist in the part/assembly, you'll be asked for a value.
Are you wondering how to use a parameter within text? Like with &param_name?
Nov 7, 2024 4:56 AM UTC
I've two parameters 'DRW_RELEASED_ON' & 'DRW_RELEASED_BY' in my creo start part with source as Windchill. We had creo 7 earlier, in which when we create a drawing, those two parameters get copied/inherited from part to drawing automatically. After our recent Creo 9 upgrade, this copy/inheritance of the parameter not happening. Is there any creo setting or config blocking it?
