How to add additional column in BOM report ?
  • September 22, 2016
  • 4 replies
  • 3194 views
Creo 3.0  -- Bill Of Material - Bom Reort
How to add additional column (say description ) in BOM report ?
i can see Quantity, Type, Name, Actions. Can we add Description column ?
Mahesh_Sharma
22-Sapphire I
September 22, 2016
gkumar-21-VisitorAuthor
Thanks Manish,
I am not able able to open the link. Not sure If any additional previlalge required. Request if you can download and share.
regards
Gyanendra
From the Tool Bar select the Add Column icon under Rows & Column.
Then click near the inside right side line of the cell, the new column will get added on right side.
Hope this will help you.
see Creo Parametric Help Center page. Output of command is configurable via bom_format configuration file option.
MH
